> > -----Original Message-----
> > From: Wilfried Busalski [mailto:w.busalski at lancier-monitoring.de]
> > Sent: Tuesday, March 21, 2006 1:46 PM
> > To: Rtems-Users
> > Subject: FTP-Server with login security
> > Hi all
> > The actual source of the ftpd.c is without any security for
> login. Has
> > anybody a patch for the ftpd.c with login security?
> > Regards
> > Wilfried Busalski
> Hi,
> I could provide a patch this week. It would allow to use the standard
> username/password (plaintext) authentication.
Hi,
I've filed a PR (927) with an attached patch which adds authentication
for
the RTEMS FTP server. To keep backwards compatibility and to have some
flexibility, there is a new value FTPD_AUTH for the access field which
enables
authentication. Thus, existing applications should not require any
changes.
* User management
typedef struct rtems_ftpd_auth
/* Request */
const char *username;
const char *password;
/* Response */
int access;
char rootdir[PATH_MAX];
} rtems_ftpd_auth_t;
typedef int (*rtems_ftpd_auth_cb_t)(rtems_ftpd_auth_t *auth, void
*user);
int rtems_ftpd_auth_add(rtems_ftpd_auth_cb_t auth_fn, void *user);
int rtems_ftpd_auth_del(rtems_ftpd_auth_cb_t auth_fn, void *user);
Authentication modules can be added by calling rtems_ftpd_auth_add()
which
registers a callback function that tells the FTP server whether access
shall be granted or not. The read/write access and root directory for
each
user is also selected by the callback function.
With the current patch, up to 8 callbacks can be registered. Of course
this could be made dynamic.
An authentication function can be unregistered by calling
rtems_ftpd_auth_del() with the same callback function and user argument.
A simple example for such a authentication function giving full R/W
access to /
would be:
static int myauth(rtems_ftpd_auth_t *auth, void *userarg)
(void) userarg;
if(!strcmp(auth->username, "username") &&
!strcmp(auth->password, "password"))
auth->access = 0;
strcpy(auth->rootdir, "/");
return 1;
return 0;
The installation of this authentication header would be like this:
rtems_ftpd_auth_add(myauth, NULL);
The FTP configuration would be:
struct rtems_ftpd_configuration rtems_ftpd_configuration =
0,
0,
0,
0,
0,
10,
0,
FTPD_AUTH,
Waiting for comments ...
Regards,
Thomas Rauscher
Thomas Rauscher
LOYTEC electronics GmbH
