Context Switch Problem
Fri May 12 12:50:14 UTC 2006
Samuel Bitton wrote:
> Hi
> I'm currently working on a new RTEMS BSP for a custom made board based around the i386ex processor.
> The software currently breaks towards the end of RTEMS initialisation, at the point where it is doing the first context switch (_Context_Switch called at the end of _Thread_Start_multitasking).
> My application only has one small init task which toggles a line indefinitely.
> Any idea what could be going wrong.
> I'm using RTEMS 4.6.4.
Have you look over this page:
  http://www.rtems.org/wiki/index.php/DebuggingHints
It has some reasons a BSP can fail.
Regards
