Context Switch Problem
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Fri May 12 14:20:52 UTC 2006
Chris Johns wrote:
> Samuel Bitton wrote:
>> Hi
>> I'm currently working on a new RTEMS BSP for a custom made board
>> based around the i386ex processor.
>> The software currently breaks towards the end of RTEMS
>> initialisation, at the point where it is doing the first context
>> switch (_Context_Switch called at the end of
>> _Thread_Start_multitasking).
>> My application only has one small init task which toggles a line
>> indefinitely.
>> Any idea what could be going wrong.
>> I'm using RTEMS 4.6.4.
> Have you look over this page:
>  http://www.rtems.org/wiki/index.php/DebuggingHints
> It has some reasons a BSP can fail.
And the most likely reason is included there -- an interrupt is pending
and you are taking
an exception.  The first context switch enables CPU interrupts and any
device not in a
quiescent state will slap you here. :)
--joel
> Regards
> Chris
