Context Switch Problem
Juergen Zeller juergen.zeller at argovision.de
Mon May 15 07:20:28 UTC 2006
some time ago I had similar problems with a custom 386ex board.
I used 4.6.0 and had an exception at the first context switch.
My problem was the fact that the macros __USE_INIT_FINI__ and
__USE_MAIN__ were defined.
in cpucit/score/src/threadhandler.c in _Thread_Handler () there was a
function call _init ().
But this call ended due to linkcmds at a point without return.
.init : { _init = .; *(.init) } = 0x9090
hope this helps - check these macros
--juergen
Samuel Bitton schrieb:
>Note that I'm relying mostly on the default RTEMS configuration.
>My application (which is a simple single init task that toggles a line indefinitely) only defines the following before including confdefs.h
>#define CONFIGURE_TERMIOS_DISABLED
>#define CONFIGURE_MAXIMUM_TASKS            2
>#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
>Is there anything I'm missing in the RTEMS config or should that be ok in which case my current guess would be a bad memory mapping from my side.
>Regards
>Sam
> -----Original Message-----
>From: 	Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
>Sent:	12 May 2006 16:21
>To:	Chris Johns
>Cc:	Samuel Bitton; rtems-users at rtems.com
>Subject:	Re: Context Switch Problem
>Chris Johns wrote:
>>Samuel Bitton wrote:
>>>Hi
>>>I'm currently working on a new RTEMS BSP for a custom made board
>>>based around the i386ex processor.
>>>The software currently breaks towards the end of RTEMS
>>>initialisation, at the point where it is doing the first context
>>>switch (_Context_Switch called at the end of
>>>_Thread_Start_multitasking).
>>>My application only has one small init task which toggles a line
>>>indefinitely.
>>>Any idea what could be going wrong.
>>>I'm using RTEMS 4.6.4.
>>Have you look over this page:
>> http://www.rtems.org/wiki/index.php/DebuggingHints
>>It has some reasons a BSP can fail.
>And the most likely reason is included there -- an interrupt is pending
>and you are taking
>an exception.  The first context switch enables CPU interrupts and any
>device not in a
>quiescent state will slap you here. :)
>--joel
>>Regards
>>Chris
