Strange timing results
Alexandre Constantino
alexandre.constantino at edisoft.pt
Thu May 18 08:45:07 UTC 2006
Hi,
I've obtained the strangest results on the tmtests (timing tests suites)
on an i386 (AMD XP 2,4 GHz) with a pc386 BSP.
For illustrations purposes, take the results for tm01:
NOTE: all times are in microseconds
rtems_semaphore_create 926
rtems_semaphore_delete 618
rtems_semaphore_obtain: available 92
rtems_semaphore_obtain: not available 92
rtems_semaphore_release 180
I have tested tm01 to tm10 and the time disparity is of the same
magnitude. I have results from 2x to 15x higher than the ones mentioned
on the i386.pdf for a 16 Mhz CPU!
Any clue on what might be wrong?
Even stranger is the fact that the same executives where tested on bochs
(*) in the very same computer, and the time results were 4x to 2x
smaller than the ones i obtained while running the executives natively.
(*) with a "tunned" IPS and clock settings - since i was able to get
some "close" delay values
Thank you for your time.
