ATA/IDE disk access using PIO and interrupt
Yan Luo yan_luo at uml.edu
Thu May 25 18:31:54 UTC 2006
Sorry, I mean
"I was trying to understand how interrupt works for the PIO as it is said in
the document (ata.t) that PIO is supported by both polling and INTERRUPT."
----- Original Message -----
To: <rtems-users at rtems.com>
Sent: Thursday, May 25, 2006 2:25 PM
Subject: ATA/IDE disk access using PIO and interrupt
> Hello All,
> in the document (ata.t) that PIO is supported by both polling and PIO.
> I don't see the IDE_Controller_Table[ctrl_minor].int_driven set to TRUE
> anywhere in the source tree. That means the interrupt driven PIO is NOT
> enabled at all.
> I tried to set it as true in ide_controller_initialize() in ide_ctrl.c.
> That caused the RTEMS hang.
> How the interrupt for PIO is enabled?
> My test is on RTEMS 4.6.2 with fileio example application.
> Thanks,
> Yan
