rtems_clock_set @ sparc v7 does not work!
Joel Sherrill
joel.sherrill at oarcorp.com
Tue May 30 15:50:52 UTC 2006
Grigori Khmyrov wrote:
> When I set new time at sparc v7 board using rtems_clock_set( &newTime
> ) function,
> at some point ticks jump back to previous value!?
> It does not happen if I use rtems_clock_set twice:
> rtems_clock_set
> rtems_clock_set
What version of RTEMS are you using? Does it have the "memory barrier"
patch?
This sounds like the interrupt critical section issue that was addressed
by that patch.
> I have same code running at i386 processor and rtems_clock_set is
> working OK.
> Any ideas?
> Thank you,
> Grigori
