rtems_clock_set @ sparc v7 does not work!
Grigori Khmyrov
grigori_khmyrov at uml.edu
Tue May 30 17:48:53 UTC 2006
Yes, it would be reasonable explanation!
I use RTEMS 4.0.0 for the sparc BSP
And 4.6.2 for i386 BSP (which works)
How can I patch "memory barrier" for version 4.0.0?
I can not switch easy to the new rtems version because of mkprom support.
Thank you,
Grigori
Joel Sherrill wrote:
> Grigori Khmyrov wrote:
>> When I set new time at sparc v7 board using rtems_clock_set( &newTime
>> ) function,
>> at some point ticks jump back to previous value!?
>> It does not happen if I use rtems_clock_set twice:
>> rtems_clock_set
>> rtems_clock_set
> What version of RTEMS are you using? Does it have the "memory
> barrier" patch?
> This sounds like the interrupt critical section issue that was
> addressed by that patch.
>> I have same code running at i386 processor and rtems_clock_set is
>> working OK.
>> Any ideas?
>> Thank you,
>> Grigori
