Installation problem for target "(none)"
Stefan.Pusl at comneon.com
Thu Nov 30 07:34:54 UTC 2006
Hello,
I have still a problem during the installation. First, I read carefully
the hints given in
http://www.rtems.com/onlinedocs/releases/rtemsdocs-4.6.6/share/rtems/htm
l/started/started00072.html, which give hints concerning Cygwin on a
Windows PC. Then I used the command
../rtems-4.6.6/configure --enable-rtemsbsp=posix --disable-rtems-inline
For the configuration of RTEMS. Then I started the installation with the
command
Make all
This command stopped with the following error message:
make[5]: Leaving directory
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libblock'
Making preinstall in libfs
make[5]: Entering directory
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libfs'
Making preinstall in src
make[6]: Entering directory
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libfs/src'
Making preinstall in imfs
make[7]: Entering directory
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libfs/src/imfs'
/usr/bin/install -c -m 644
../../../../../../../rtems-4.6.6/c/src/../../cpukit/libfs/src/imfs/imfs.
h ../../../../../../posix/lib/include/imfs.h
make[7]: Leaving directory
Making preinstall in dosfs
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libfs/src/dosfs'
Makefile:518: *** multiple target patterns. Stop.
make[6]: *** [preinstall-recursive] Error 1
make[6]: Leaving directory
make[5]: *** [preinstall-recursive] Error 1
make[4]: *** [preinstall-recursive] Error 1
make[4]: Leaving directory
`/cygdrive/h/GNU/new_rtems/build/c/posix/exec'
make[3]: *** [preinstall-recursive] Error 1
make[3]: Leaving directory `/cygdrive/h/GNU/new_rtems/build/c/posix'
make[2]: *** [posix] Error 1
make[2]: Leaving directory `/cygdrive/h/GNU/new_rtems/build/c'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/cygdrive/h/GNU/new_rtems/build/c'
make: *** [all-recursive] Error 1
According to the error message I attach the "Makefile" located in the
path
'/cygdrive/h/GNU/new_rtems/build/c/posix/exec/libfs/src/dosfs'
<<Makefile>>
According to the hint of one expert I try now the configure-command
without the option '--disable-rtems-inline'
Best regards
Stefan
Desc: Makefile
URL: <http://lists.rtems.org/pipermail/users/attachments/20061130/c1d0da4a/attachment.obj>
