Problem report: Struct aliasing problem	causes	Thread_Ready_Chain	corruption in 4.6.99.3
    Thomas Doerfler
    Thomas.Doerfler at embedded-brains.de
    Tue Nov 28 17:35:07 UTC 2006
Ralf,
I have compiled RTEMS-4.7.branch fpr the MBX821_001b BSP with and
without the patch I posted some days ago. I have analyzed the assembly
code for the function "threadresettimeslice.c" and (Ralf this should be
interesting for you) found that the unpatched version generates WRONG code.
This is going to get lengthy, but it is worth writing:
Here is the function body of thread_reset_timeslice:
void _Thread_Reset_timeslice( void )
  ISR_Level       level;
  Thread_Control *executing;
  Chain_Control  *ready;
  executing = _Thread_Executing;
  ready     = executing->ready;
  _ISR_Disable( level );
    if ( _Chain_Has_only_one_node( ready ) ) {
      _ISR_Enable( level );
      return;
/**** COMMENT: these two lines generate nonfunctional code *****/
    _Chain_Extract_unprotected( &executing->Object.Node );
    _Chain_Append_unprotected( ready, &executing->Object.Node );
/**** COMMENT: end of critical lines *****/
  _ISR_Flash( level );
    if ( _Thread_Is_heir( executing ) )
      _Thread_Heir = (Thread_Control *) ready->first;
    _Context_Switch_necessary = TRUE;
The inlined functions "_Chain_Extract_unprotected" and
"_Chain_Append_unprotected" look like this:
RTEMS_INLINE_ROUTINE void _Chain_Extract_unprotected(
  Chain_Node *the_node
  Chain_Node *next;
  Chain_Node *previous;
  next           = the_node->next;
  previous       = the_node->previous;
  next->previous = previous;
  previous->next = next;
RTEMS_INLINE_ROUTINE void _Chain_Append_unprotected(
  Chain_Control *the_chain,
  Chain_Node *old_last_node;
  the_node->next      = _Chain_Tail(the_chain);
  old_last_node       = the_chain->last;
  the_chain->last     = the_node;
  old_last_node->next = the_node;
  the_node->previous  = old_last_node;
So they are basic chain/unchain operations.
Here is, what the compiler created from this source code and my comments
to it:
============== start of non-functional version ==================
 	lwz     r6,8(r5);  r6 = ready->last (=old_last_node);
 	lwz     r0,0(r5);  r0 = ready->first;
 	addi    r4,r5,4 ;  r4 = &(ready->premanent_null)
 	cmpw    cr7,r0,r6
 	bne-    cr7,48 <_Thread_Reset_timeslice+0x48>
 	mtmsr   r7
 	blr                ; r8==executing, r5==ready
; extract starts here
 	lwz     r11,0(r8)  ; r11=executing->next
 	lwz     r9,4(r8)   ; r9 =executing->previous
 	stw     r11,0(r9)  ; executing->prev->next=executing->next
 	stw     r9,4(r11)  ; executing->next->prev=executing->prev
; append starts here
 	stw     r4,0(r8)   ; executing->next=&(ready->premanent_null)
 	stw     r8,8(r5)   ; ready->last = executing
 	stw     r6,4(r8)   ; executing->prev=old_last_node(taken LONG ago)
 	stw     r8,0(r6)   ; old_last_node->next=executing
 	mtmsr   r7
 	andc    r10,r7,r10
 	mtmsr   r10
============== end of non-functional version ==================
Please note: the above code reads "ready->last" to "old_last_node(=r6)"
once at the top of this snipplet, and the compiler has no idea, that the
node chaining operations below might modify "read->last", because *ready
is not of type "Chain_Node".
What might happen:
executing is the last node in the chain, so executing-next points to
ready and the line commented as "executing->next->prev=executing->prev"
modifies in fact "ready->last", but later on, the code still uses the
(stale) copy of ready->last located in register r6. And THIS IS WRONG.
Here is the code generated with my patches (and still with
strict-aliasing ON)
============== start of fixed version ==================
 	lwz     r9,0(r5);  r9 = ready->first;
 	lwz     r0,8(r5);  r0 = ready->last (=old_last_node);
 	addi    r4,r5,4
 	cmpw    cr7,r9,r0
 	mtmsr   r6
 	blr
 	lwz     r10,8(r5)  ; old_last_node=ready->last
 	stw     r8,0(r10)  ; old_last_node->next=executing
 	stw     r10,4(r8)  ; executing->prev=old_last_node
 	mtmsr   r6
 	andc    r7,r6,r7
 	mtmsr   r7
============== end of fixed version ==================
Here you can see, that "old_last_node" is taken at the proper time.
So, I think I could prove that the current GCC miss-interprets and
mis-optimizes RTEMS chain code in a rather subtile way.
The current code/compiler adaptation is broken. And we have just
analyzed ONE function.
by the way: my patch (overlaying Chain_Control with two Chain_node
structures and accessing Chain_Control through these structures) is not
yet clean enough to be integrated into RTEMS, because, as Pavel has
pointed out, it will have alignment problems on some machines.
wkr,
Thomas.
Ralf Corsepius schrieb:
> On Tue, 2006-11-28 at 09:12 -0600, Eric Norum wrote:
>> In the interests of not delaying 4.7 for another year I suggest that
>> we simply add -fno-strict-aliasing to all gcc invocations.  I don't
>> see anything wrong with this approach in the near term.  As has been
>> pointed out by others, many other kernel development projects have
>> resorted to this technique.
>> I know that Ralf is opposed to this, but I have not heard a reason to
>> convince me.
> And I have not seen any bug in RTEMS having been fixed by
> -fno-strict-aliasing.
> However, I've seen a lot of people bogusly accusing strict-aliasing for
> code bugs, in general (Outside of RTEMS).
> Please folks, please provide cases, so we can go after this. So far this
> has not taken place, instead I've seen several "flare gun" approaches
> having been proposed.
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
embedded brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
Tel. : +49-89-18 90 80 79-2
Fax  : +49-89-18 90 80 79-9
email: Thomas.Doerfler at embedded-brains.de
PGP public key available on request
