overriding RTEMS_BSPOPTS_SET option
Ralf Corsepius ralf.corsepius at rtems.org
Mon Oct 9 06:23:35 UTC 2006
On Sat, 2006-10-07 at 00:26 -0400, John Wood wrote:
> Where do I override an option set to a default value with
> the RTEMS_BSPOPTS_SET  in a  BSP configure script?
>   Could someone provide an example by any chance?
The 3rd argument of RTEMS_BSPOPTS_SET is the default value.
If you want to override the default, then you need to derive a new BSP
from the existing one.
If you want to pass a specific value to a BSP, you can pass it through
the environment at configuration time.
./configure --target=<mytarget>
make RTEMS_BSP=
make RTEMS_BSP=<mybsp> XXXX=<value>
Ralf
