ERC32 ticks
Mon Oct 16 15:12:12 UTC 2006
Aleix Conchillo Flaqué wrote:
> Hi,
> I'm trying to run some simple examples based on timers and there are
> some things I don't quite understand.
> I've seen that the ERC32 BSP uses the RTC as the clock driver, which
> is in charge of calling rtems_clock_tick() (from the ISR) which
> increments the internal tick counters (TOD, Watchdog, ...).
> Everything fine, by now.
> Then, I've used the rtems_clock_get with
> RTEMS_CLOCK_GET_TICKS_SINCE_BOOT to get the current ticks since boot,
> and it has returned me 100 (I haven't configured anything). Is this
> correct? With this value I can't even have millisecond precision,
> thus calling RTEMS_MILLISECONDS_TO_TICKS (1234) I get 123 ticks,
> which is correct for the 100 ticks given, but doesn't make much sense.
> This might be obvious, am I missing something?
Only that you need to set CONFIGURE_MICROSECONDS_PER_TICK to match what
your application requires balancing overhead with timing granularity
required.
#ifndef CONFIGURE_MICROSECONDS_PER_TICK
#define CONFIGURE_MICROSECONDS_PER_TICK
RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
#endif
> Thanks in advance.
> Regards,
> aleix
> rtems-users mailing list
> rtems-users at rtems.com
