ERC32 ticks
Aleix Conchillo Flaqué aconchillo at ieec.fcr.es
Mon Oct 16 15:43:20 UTC 2006
So, this is a must have in the configuration, as the value given by
default is almost unuseful.
Why is this default value given? Isn't 100 ticks per second so small?
On 16 Oct 2006, at 17:12, Joel Sherrill wrote:
> Only that you need to set CONFIGURE_MICROSECONDS_PER_TICK to match
> what
> your application requires balancing overhead with timing granularity
> required.
> #ifndef CONFIGURE_MICROSECONDS_PER_TICK
> #define CONFIGURE_MICROSECONDS_PER_TICK
> RTEMS_MILLISECONDS_TO_MICROSECONDS(10)
> #endif
