gethostbyname_r
Steven Johnson sjohnson at sakuraindustries.com
Thu Oct 19 09:02:08 UTC 2006
Hello,
Please consider the attached patch.
It adds a functional gethostbyname_r to rtems.  We were having problems
with multiple threads calling gethostbyname, so we decided the best way
to deal with it was to do it properly, rather than kludge up our code to
make gethostbyname safe.
We have found several slightly different parameter lists for this
function, it doesn't seem to be standard. The one we used has the linux
interface.  In rtems there was an existing gethostbyname_r inside a
"#ifdef _THREAD_SAFE" which was NOT Threadsafe, as this just called
gethostbyname. So we have placed all of the additional code inside the
#ifdef _THREAD_SAFE.
The code mainly came from COMOS a no license project available from
sourceforge. Our main change was to read the hosts file in a similar way
to the current rtems gethostent, instead of the original which used mmap.
We have tested it looking up 2 addresses in different threads at the
same time and we have tested looking in the hosts file (localhost). We
have also tested outside of our subnet.
This patch is against 4.6.99.3
Best Regards,
Steven Johnson
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20061019/1e8c82e3/attachment.bin>
