Really need some help with RTEMS networking semaphores
Ian Caddy ianc at goanna.iinet.net.au
Mon Oct 23 02:30:21 UTC 2006
Hi Greg,
gregory.menke at gsfc.nasa.gov wrote:
> I don't yet know to what extent mbufs are allocated without clusters,
> but since at least the receive packets use mbufs with clusters, sizing
> the cluster buffer so each mbuf can get one seems at least arguably
> useful.
For transmission, it depends on the size of the packet being sent as to
whether or not a single mbuf is used or a cluster is required.  From
memory, if the packet is smaller than 208 bytes, a single mbuf (or two)
will be used.  Larger than that, and a cluster is allocated.
We had a problem sometime in the past, with a legacy application running
on a PC, that could not handle fragmented packets coming in on TCP.  We
found that if we tried to send a packet between 100 bytes (MLEN) and 208
bytes (MCLBYTES) then the packet is broken into 2 mbufs and sent
seperately.  The PC that it was connected to was very fast, but the
application very old, and it would see the first half of the packet and
throw it away as it wasn't complete, then the other half would arrive,
which wasn't a valid message and would also be thrown away.
This caused us some interesting times and that is why I know about the
sending of TCP packets ... ;-)
regards,
Ian Caddy
Ian Caddy
Goanna Technologies Pty Ltd
+61 8 9221 1860
