Need to rebuild RTEMS after replacing libgcc.a?
Alan Cudmore
Alan.P.Cudmore at nasa.gov
Mon Oct 23 14:22:37 UTC 2006
Recently we noticed a bug on our m68k GCC-3.3.3 software floating
point library.
The bug is in the libgcc.a __truncdfsf2 function which is from the
fpgnulib.c file.
After we fix this problem, we would like to replace the libgcc.a in
our gcc/rtems installation. Does anyone know if I should rebuild
RTEMS to pick up changes in the new libgcc.a file, or does that only
get brought in when linking an RTEMS application?
I know the samples that get put in the rtems/m68k-rtems directory
would need to be re-linked, but those are not too important.
Thanks,
Alan
