RTEMS wikipedia page
Joel Sherrill
joel.sherrill at oarcorp.com
Tue Sep 12 13:57:28 UTC 2006
Alain Schaefer wrote:
> Hi,
> Well one day I had to step out of the shadow :-)
> I do have an initial port. The basic tests
> (Hello World, Timer, Paranoid etc.) are working. More
> advanced test cases still have a couple of probs.
From an RTEMS perspective, the port needs to be merged.
It is basically functional and you are addressing problems from
here out.
We can merge it on the head since I just branched 4.7.
> The Port has not yet been published because the
> bfin toolchain needs to improve a bit to work with
> ralfs crossrpm magic.
The tools will catch up. If you can compile it and run tests,
then it will just take time for all the pieces to fall into place.
I haven't even mentioned the CPU Supplement chapter to you
because I wanted to simplify the documentation format before
getting you involved.
> I thought about publishing the current state of the patches
> + instructions on a page separate from rtems.com <http://rtems.com>.
> Joel + Ralf, would that be ok until we sort out
> this libssp problem ?
I will leave it to Ralf for the tool issues but the port itself sounds
like it is functionally complete and just needs time to work out the
warts. It will be easier to deal with from CVS.
> alain
> On 9/12/06, * Fabrício de Novaes Kucinskis* <fabricio at dea.inpe.br
> <mailto:fabricio at dea.inpe.br>> wrote:
> Hi Joel,
> Does RTEMS have a Blackfin BSP? This is listed in the wikipedia's
> page, but
> not on the RTEMS Targets page (
> http://www.rtems.com/targets.html), nor in
> the list of issues solved and improvements on the official page.
> One more thing: this issue still remains as a "possible candidate" in
> http://www.rtems.com/wiki/index.php/RTEMS48Ideas
> <http://www.rtems.com/wiki/index.php/RTEMS48Ideas>.
> Which one is correct?
> Regards,
> Fabrício.
> -----Mensagem original-----
> De: Joel Sherrill [mailto: joel.sherrill at oarcorp.com
> <mailto:joel.sherrill at oarcorp.com>]
> Enviada em: segunda-feira, 11 de setembro de 2006 16:42
> Para: RTEMS Users Mailing List
> Assunto: RTEMS wikipedia page
> Hi,
> I have attempted to enhance the wikipedia page for RTEMS.
> http://en.wikipedia.org/wiki/RTEMS
> <http://en.wikipedia.org/wiki/RTEMS>
> I would appreciate it if you all would review it and edit
> it.
> If you know of a project or application that is already
> in Wiki, please cross-links it to the RTEMS applications/projects that
> already have Wikipedia
> entries.
> Thanks.
> --joel
