NFS Performance
Steven Johnson
sjohnson at sakuraindustries.com
Wed Sep 13 04:27:59 UTC 2006
Well we tried this and defining HAVE_BLKSIZE did not break our program.
BUT the st_blksize is set to 4096 bytes, and we know that max
performance seems to be when it is 8K. The problem is we can't find
where the 4K for st_bufsize is being set. Its being copied by nfs from
an fattr structure (line 2838 in nfs.c, right under a suspicious TODO
comment), but where the fattr structure gets the 4k from is currently a
mystery. We could just hack NFS to not copy it from the fattr structure
and force it to 8K, but this doesn't seem the right thing to do.
Steven Johnson
Till Straumann wrote:
> Here's something (regarding default block size used by newlib/stdio) I
> found out:
> If newlib was compiled with HAVE_BLKSIZE defined then it would use
> the st_blksize information [newlib makebuf.c does a 'stat' anyways] when
> configuring the default buffer for stdio.
> Some filesystems (msdos, nfs) do set st_blksize, others (imfs) do not
> but since libcsupport/src/stat.c does zero-out the stat buf argument
> [and newlib uses BUFSIZ for st_bufsz <= 0] I believe defining
> HAVE_BLKSIZE should be OK.
> We could use this trick to let rtems NFS transparently increase the
> buffer size for
> stdio to 8k (nfs v2 limit).
> -- Till
>>>>> Joel, Thanks for the pointer. setvbuf worked like a treat. So, we
>>>>> don't
>>>>> have to hack stdio.h, thanks for the suggestion.
>>>> I'm glad setvbuf worked. It is always nice to not hack at a standard
>>>> include file.
>>>>> Following are some benchmarks we got with different block sizes.
>>>>> MPC862
>>>>> Processor (PowerPC) at 100Mhz, with 50Mhz SDRAM main memory and using
>>>>> the FEC (Fast Ethernet Controller @ 100Mbit/s, full duplex), its a
>>>>> custom design and doesn't use a standard BSP, but isn't dissimilar to
>>>>> the standard MPC862 BSP:
>>>>> Times to transfer the 7.4M test file timed using ticks_since_boot, (1
>>>>> tick is 10ms on our target):
>>>>> Buffer Size @ Ticks to transfer = ~Mbit/s
>>>>> 256 @ 4265 = ~1.4Mbit/s
>>>>> 512 @ 2221 = ~2.7Mbit/s
>>>>> 1024 @ 1239 = ~4.8Mbit/s
>>>>> 2048 @ 712 = ~8.4Mbit/s
>>>>> 4096 @ 439 = ~13.7Mbit/s
>>>>> 8192 @ 298 = ~20.2Mbit/s
>>>>> 16384 @ 299 =~20.2Mbit/s
>>>>> 32768 @ 298 =~20.2Mbit/s
>>>> You don't mention what the NFS server is and how it does from
>>>> a similar host.
>> The NFS Server is a Linux Box (Linux version 2.4.21-0.13mdk, Mandrake
>> Linux 9.1)
>> It is a 2.7Ghz P4 with 1GB of ram.
>> Ethernet controller: Broadcom Corporation BCM4401 100Base-T.
>> From a similarly spec'd Linux box, between the machines, we can sustain
>> about 88Mbit/s NFS transfer rate, with a single file transfer. Not
>> unsurprisingly, given the sophisticated caching, etc in linux setvbuf
>> has no effect on the speed of NFS on the linux box. I don't know if the
>> 20Mbit/s from our rtems box is a limit on our MPC862's processing
>> performance or the performance of the FEC, or deficiencies in the NFS
>> stack. Probably all of the above. Yet given the relative level's of
>> complexity, 20Mbit/s is very respectable in my opinion. It is certainly
>> fast enough for our application's needs.
>>> done - I incorporated the comments I posted yesterday into the README.
>>> Also, I added a test code.
>>> -- T.
>> That's great. I'll throw up a Wiki topic on it soon.
>> Steven J
