NFS Performance
Till Straumann
strauman at slac.stanford.edu
Wed Sep 13 06:19:12 UTC 2006
Steven Johnson wrote:
> Well we tried this and defining HAVE_BLKSIZE did not break our program.
> BUT the st_blksize is set to 4096 bytes, and we know that max
> performance seems to be when it is 8K. The problem is we can't find
> where the 4K for st_bufsize is being set. Its being copied by nfs from
> an fattr structure (line 2838 in nfs.c, right under a suspicious TODO
> comment), but where the fattr structure gets the 4k from is currently a
> mystery.
It's the block size of the file on the server [I had looked at linux -
there is
no way to tune this for the linux NFS server]
> We could just hack NFS to not copy it from the fattr structure
> and force it to 8K, but this doesn't seem the right thing to do.
Why not? That's just what I would do - supposedly,
"The value st_blksize gives the "preferred" blocksize for efficient
file system I/O."
I'd make it a run-time tunable feature by means of a global flag.
Comments?
-- T.
> Steven Johnson
> Till Straumann wrote:
>> Here's something (regarding default block size used by newlib/stdio) I
>> found out:
>> If newlib was compiled with HAVE_BLKSIZE defined then it would use
>> the st_blksize information [newlib makebuf.c does a 'stat' anyways] when
>> configuring the default buffer for stdio.
>> Some filesystems (msdos, nfs) do set st_blksize, others (imfs) do not
>> but since libcsupport/src/stat.c does zero-out the stat buf argument
>> [and newlib uses BUFSIZ for st_bufsz <= 0] I believe defining
>> HAVE_BLKSIZE should be OK.
>> We could use this trick to let rtems NFS transparently increase the
>> buffer size for
>> stdio to 8k (nfs v2 limit).
>> -- Till
>>>>>> Joel, Thanks for the pointer. setvbuf worked like a treat. So, we
>>>>>> don't
>>>>>> have to hack stdio.h, thanks for the suggestion.
>>>>> I'm glad setvbuf worked. It is always nice to not hack at a standard
>>>>> include file.
>>>>>> Following are some benchmarks we got with different block sizes.
>>>>>> MPC862
>>>>>> Processor (PowerPC) at 100Mhz, with 50Mhz SDRAM main memory and using
>>>>>> the FEC (Fast Ethernet Controller @ 100Mbit/s, full duplex), its a
>>>>>> custom design and doesn't use a standard BSP, but isn't dissimilar to
>>>>>> the standard MPC862 BSP:
>>>>>> Times to transfer the 7.4M test file timed using ticks_since_boot, (1
>>>>>> tick is 10ms on our target):
>>>>>> Buffer Size @ Ticks to transfer = ~Mbit/s
>>>>>> 256 @ 4265 = ~1.4Mbit/s
>>>>>> 512 @ 2221 = ~2.7Mbit/s
>>>>>> 1024 @ 1239 = ~4.8Mbit/s
>>>>>> 2048 @ 712 = ~8.4Mbit/s
>>>>>> 4096 @ 439 = ~13.7Mbit/s
>>>>>> 8192 @ 298 = ~20.2Mbit/s
>>>>>> 16384 @ 299 =~20.2Mbit/s
>>>>>> 32768 @ 298 =~20.2Mbit/s
>>>>> You don't mention what the NFS server is and how it does from
>>>>> a similar host.
>>> The NFS Server is a Linux Box (Linux version 2.4.21-0.13mdk, Mandrake
>>> Linux 9.1)
>>> It is a 2.7Ghz P4 with 1GB of ram.
>>> Ethernet controller: Broadcom Corporation BCM4401 100Base-T.
>>> From a similarly spec'd Linux box, between the machines, we can sustain
>>> about 88Mbit/s NFS transfer rate, with a single file transfer. Not
>>> unsurprisingly, given the sophisticated caching, etc in linux setvbuf
>>> has no effect on the speed of NFS on the linux box. I don't know if the
>>> 20Mbit/s from our rtems box is a limit on our MPC862's processing
>>> performance or the performance of the FEC, or deficiencies in the NFS
>>> stack. Probably all of the above. Yet given the relative level's of
>>> complexity, 20Mbit/s is very respectable in my opinion. It is certainly
>>> fast enough for our application's needs.
>>>> done - I incorporated the comments I posted yesterday into the README.
>>>> Also, I added a test code.
>>>> -- T.
>>> That's great. I'll throw up a Wiki topic on it soon.
>>> Steven J
