RTEMS Self Task Deletion
Wed Sep 27 08:47:20 UTC 2006
Kamaraj P wrote:
> I mean the memory allocated by Task (while creation) for TCB, STACK size etc.
The memory allocated for the stack plus some other bits and pieces
should be released back into the Workspace. How do you know the memory
is not being released ?
The object data will be returned the free list of objects and may not be
released. This depends on the configuration table entries and if you
have the unlimited bit set. In this case the object memory may have been
allocated when the create occurs and will not be released until half the
allocation size of the previous block has been released.
Regards
