RTEMS Self Task Deletion
Kamaraj P
pkamaraj at Centillium.com
Wed Sep 27 09:21:16 UTC 2006
This is confirmed by repeatedly attempting to create the same task. At some point, we observed that the task creation is failed due to the lack of resources; This is due to memory draining.
I have also confirmed the behavior by doing another approach;
Attempting to delete the task before creating the task in the caller context run successfully without any issues.
Regards,
Kamaraj
-----Original Message-----
Sent: Wednesday, September 27, 2006 2:17 PM
To: Kamaraj P
Cc: Fabrício de Novaes Kucinskis; rtems-users at rtems.com
Subject: Re: RTEMS Self Task Deletion
Kamaraj P wrote:
> I mean the memory allocated by Task (while creation) for TCB, STACK size etc.
The memory allocated for the stack plus some other bits and pieces
should be released back into the Workspace. How do you know the memory
is not being released ?
The object data will be returned the free list of objects and may not be
released. This depends on the configuration table entries and if you
have the unlimited bit set. In this case the object memory may have been
allocated when the create occurs and will not be released until half the
allocation size of the previous block has been released.
Regards
