RTEMS Self Task Deletion
Joel Sherrill
joel.sherrill at oarcorp.com
Wed Sep 27 13:01:50 UTC 2006
Chris Johns wrote:
> Kamaraj P wrote:
>> Please find the sample code. This may not be directly compliable.
> Ok.
>> Could you please let me know he can we verify whether self task has
>> been deleted successfully or not.
> Are you sure the tasks you create are able to run ?
> Your creation loop will not block for any period of time if its
> priority is higher than the tasks you create.
> Please try the following main:
> int main()
> rtems_task_priority old_priority;
> rtems_mode old_mode;
> rtems_task_set_priority(RTEMS_SELF, 254, &old_priority);
> rtems_task_mode(RTEMS_PREEMPT, RTEMS_PREEMPT_MASK, &old_mode);
> Test();
> return 0;
It main() is a Class API init task, once it returns, there will be a
fatal error and
the system will halt.
>> I am not sure checking the return status of
>> rtems_task_delete (RTEMS_SELF) will help. Because the self task context
>> (to be deleted) where you executing print message will not print on
>> the console.
>> Even before that the task would have been deleted . Please correct me
>> If I am wrong.
> Nothing after the delete self will run.
> Regards
> Chris
