RTEMS Self Task Deletion
Chris Johns
chrisj at rtems.org
Wed Sep 27 12:40:51 UTC 2006
Kamaraj P wrote:
> Please find the sample code. This may not be directly compliable.
Ok.
> Could you please let me know he can we verify whether self task has been
> deleted successfully or not.
Are you sure the tasks you create are able to run ?
Your creation loop will not block for any period of time if its priority
is higher than the tasks you create.
Please try the following main:
int main()
rtems_task_priority old_priority;
rtems_mode old_mode;
rtems_task_set_priority(RTEMS_SELF, 254, &old_priority);
rtems_task_mode(RTEMS_PREEMPT, RTEMS_PREEMPT_MASK, &old_mode);
Test();
return 0;
> I am not sure checking the return status of
> rtems_task_delete (RTEMS_SELF) will help. Because the self task context
> (to be deleted) where you executing print message will not print on the console.
> Even before that the task would have been deleted . Please correct me If I am wrong.
Nothing after the delete self will run.
Regards
