Emulating clock ISR
Ingolf Steinbach Ingolf.Steinbach at jena-optronik.de
Wed Apr 4 12:40:03 UTC 2007
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Thomas Doerfler schrieb:
> rtems_clock_tick() is the interface between the periodic system timer
> interrupt and the time maintained in RTEMS. For your ISR it is sufficent
> to call rtems_clock_tick() to replace the standard clock driver.
I understand that rtems_clock_tick() will also handle all the
task switching etc. Is this correct?
> Do you really want to feed a 1MHz signal as an interrupt to your system?
No, of course not. I noticed that wrong number, too, as usual
shortly after the e-mail had been sent, but did not bother to
send a correction afterwards, as the frequency was not the main
issue here. Thanks anyway for pointing it out.
Kind regards
Ingolf
Ingolf Steinbach
Software Engineer
Jena-Optronik GmbH
Prüssingstraße 41
07745 Jena
Tel: +49 3641 200-216
Fax: +49 3641 200-220
E-Mail: ingolf.steinbach at jena-optronik.de
http://www.jena-optronik.de
President & CEO: Dietmar Ratzsch I CFO: Dr. Harald Bruhn
Sitz der Gesellschaft: Jena  l  Handelsregister: AG Jena HRB 201.869
Diese E-Mail enthält vertrauliche und/oder rechtlich geschützte
Informationen. Wenn Sie nicht der richtige Adressat sind, oder diese
E-Mail irrtümlich erhalten haben, informieren Sie bitte sofort den
Absender und vernichten Sie diese E-Mail. Das unerlaubte Kopieren sowie
die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
This message is intended to be confidential and may be privileged. If
you are not the intended recipient, please delete this e-mail from your
system immediately and notify us of the erroneous transmission to you.
Any disclosure, use, copying, or distribution of this E-mail is
prohibited.
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.6 (MingW32)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
iD8DBQFGE5yjPugQggQN1ScRAiiZAKCjaJMh86rIEBhtYfay2ZDbz2ZiEQCfYvwE
ezowEsHkSQmMaC3regBl1rE=
=JsMg
-----END PGP SIGNATURE-----
