rtems_semaphore_obtain
    John Pickwick
    john.pickwick at free.fr
    Wed Apr  4 18:50:47 UTC 2007
Hi,
on that thread, after Jiri's last message, it is unclear to me if there is
still a problem for LEON2 BSP in the official 4.6.5 release (from RTEMS
site).
Please can someone clarify this point, thanx
John
----- Original Message -----
From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
To: "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>
Cc: <rtems-users at rtems.org>
Sent: Thursday, March 29, 2007 10:22 PM
Subject: Re: rtems_semaphore_obtain
> Thomas Doerfler (nt) wrote:
>> -----BEGIN PGP SIGNED MESSAGE-----
>> Hash: SHA1
>> Hi,
>> Some while ago we had a thread on the rtems mailing list which might
>> handle your problem. We found out, that gcc takes the liberty to move
>> some memory accesses that should occure between the irq disable/enable
>> calls to a location before or after the irq disabled section. Try
>> looking for a keyword like "memory barrier" on the mailing list archive
> This was my first guess also but it fails with the edge of the 4.6 and
> 4.7 branches
> as well as using events for synchronization so it is most likely not the
> barrier problem
> again.
> --joel
>> wkr,
>> Thomas.
>> Johan Zandin schrieb:
>>> Sergei Organov  writes:
>>>> "Johan Zandin" <johan.zandin at space.se> writes:
>>>>>       _Context_Switch( &executing->Registers, &heir->Registers );
>>>>>       executing = _Thread_Executing;
>>>>>       _ISR_Disable( level );         -----+
>>>>>                                           |  Region where
>>>>>    }                                      |  an occuring
>>>>>                                           |  interrupt
>>>>>     _Thread_Dispatch_disable_level = 0;   |  causes problems
>>>>>     _ISR_Enable( level );            -----+
>>>> But how interrupt can occur when it's disabled in this region?! If
>>>> _ISR_Disable()/_ISR_Enable() don't work on your target, you have hard
>>>> trouble anyway.
>>> The HW interrupt occurs but is left pending until ISRs are enabled,
>>> so the ISR does not execute until somewhere within the _ISR_Enable call
>>> (in the first cycle when ISRs are enabled in the CPU again).
>>> /Johan
>>> Johan Zandin                      Software Engineer
>>> Saab Space AB                     Phone: +46-31-735 41 47
>>> SE-405 15 Gothenburg, Sweden      Fax:   +46-31-735 40 00
>>> rtems-users mailing list
>>> rtems-users at rtems.com
>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>> IMD Ingenieurbuero fuer Microcomputertechnik
>> Thomas Doerfler           Herbststrasse 8
>> D-82178 Puchheim          Germany
>> email:    Thomas.Doerfler at imd-systems.de
>> PGP public key available at:
>>      http://www.imd-systems.de/pgpkey_en.html
>> -----BEGIN PGP SIGNATURE-----
>> Version: GnuPG v1.2.5 (MingW32)
>> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
>> iD8DBQFGDBMswHyg4bDtfjQRAshFAJ9CCTaeF89pnc0/43dHX8OzUDnM2QCgjmuz
>> LIoRrwohAlRbJJfF5mPNigk=
>> =ihwI
>> -----END PGP SIGNATURE-----
