interrupt handle?
kang yunho ttorse at hotmail.com
Thu Apr 12 12:05:26 UTC 2007
This is my first message to this list.
I am a begginer user of RTEMS and I have to program a EP7312
The program works O.K. except that I can`t execute muy own interrupt
routine
I am using the "rtems_interrupt_catch" routine to assign my routine to
the
interrupt vector. The IRQ of the URXINT2 20
Does anybody tell me if I have to do something else or I have to change
any
configuration parameter?
The vector number to the rtems_interrupt_catch is my IRQ= 20?
Here is ep7312 irq.h, if you can look at it and tell me if there is
something
wrong,
I will be gratefull for you for ever.
#define VECTOR_TABLE	 0x40
#ifndef __asm__
 * Include some preprocessor value also used by assember code
extern void default_int_handler();
| Constants
  /* enum of the possible interrupt sources */
typedef unsigned int rtems_irq_number;
  /* int interrupt status/mask register 1 */
#define BSP_EXTFIQ     0
#define BSP_BLINT      1
#define BSP_WEINT      2
#define BSP_MCINT      3
#define BSP_CSINT      4
#define BSP_EINT1      5
#define BSP_EINT2      6
#define BSP_EINT3      7
#define BSP_TC1OI      8
#define BSP_TC2OI      9
#define BSP_RTCMI     10
#define BSP_TINT      11
#define BSP_UTXINT1   12
#define BSP_URXINT1   13
#define BSP_UMSINT    14
#define BSP_SSEOTI    15
 /* int interrupt status/mask register 2 */
#define BSP_KBDINT    16
#define BSP_SS2RX     17
#define BSP_SS2TX     18
#define BSP_UTXINT2   19
#define BSP_URXINT2   20
 /* int interrupt status/mask register 3 */
#define BSP_DAIINT    21
#define BSP_MAX_INT   22
_________________________________________________________________
편리한 웹하드가 최대 1G 까지 무료!
http://im.msn.co.kr/new/function/function_02_11.asp
