error multiple target patterns
Vivian Paola Guerrero Rodriguez
vivianpaolag at hotmail.com
Wed Apr 25 19:25:48 UTC 2007
Hi,
I'm not building inside of the source tree. I'm sending the config.log file
that was created in my last intent.
thank you
>From: Ralf Corsepius <ralf.corsepius at rtems.org>
>To: Vivian Paola Guerrero Rodriguez <vivianpaolag at hotmail.com>
>CC: rtems-users at rtems.org
>Subject: Re: error multiple target patterns
>Date: Wed, 25 Apr 2007 17:31:35 +0200
>On Wed, 2007-04-25 at 14:47 +0000, Vivian Paola Guerrero Rodriguez
>wrote:
> > Hi,
> > I'm installing rtems rtems-4.7.1.tar.bz2 with rtems4.7-i386-4.exe on my
>PC
> > winXP using cygwin, but when i compile this configure
> > ..src/rtems-4.7.1/configure --disable-tests --enable-multilib
> > --target=i386-rtems4.8 --prefix=/cygdrive/c/rtems/i386/ --enable-posix
> > --enable-networking --enable-cxx --enable-rtemsbsp="pc386 pc486"
> > it creates the make files, after that when I carry out
> > make all install
> > there appears that error *** multiple target patterns. Stop.
> > Making all in score
> > make[6]: Entering directory
> > `/cygdrive/c/rtems-source/build/i386-rtems4.8/m486/cpukit/score'
> > src/.deps/libscore_a-apiext.Po:1: *** multiple target patterns. Stop.
>Are you building inside of the source tree?
> > `/cygdrive/c/rtems-source/build/i386-rtems4.8/cpukit'
> > make: *** [all-recursive] Error 1
>Please send me
>your /cygdrive/c/rtems-source/build/i386-rtems4.8/cpukit/config.log
>which should have been created when running make.
>Ralf
_________________________________________________________________
Mortgage rates near historic lows. Refinance $200,000 loan for as low as
$771/month*
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f8&disc=y&vers=689&s=4056&p=5117
Desc: not available
URL: <http://lists.rtems.org/pipermail/users/attachments/20070425/a6c3adab/attachment.obj>
