rtems_semaphore_obtain
Wed Apr 4 20:33:52 UTC 2007
John Pickwick wrote:
> Hi,
> on that thread, after Jiri's last message, it is unclear to me if there is
> still a problem for LEON2 BSP in the official 4.6.5 release (from RTEMS
> site).
> Please can someone clarify this point, thanx
Jiri ships a version of RTEMS with some patches that may or may not be in
the official tree at any given point in time.  He will have to comment
on what
is in his current patch set.
But so far, we haven't found anything wrong with RTEMS based upon the
test code.
So far it looks like the code is generating interrupts faster than they
can be processed
and eventually blowing the stack.  There must be enough time between
interrupts
so you do all cleanup from the interrupted task eventually.
--joel
> John
> ----- Original Message -----
> From: "Joel Sherrill" <joel.sherrill at oarcorp.com>
> To: "Thomas Doerfler (nt)" <Thomas.Doerfler at imd-systems.de>
> Cc: <rtems-users at rtems.org>
> Sent: Thursday, March 29, 2007 10:22 PM
> Subject: Re: rtems_semaphore_obtain
>> Thomas Doerfler (nt) wrote:
>>> -----BEGIN PGP SIGNED MESSAGE-----
>>> Hash: SHA1
>>> Hi,
>>> Some while ago we had a thread on the rtems mailing list which might
>>> handle your problem. We found out, that gcc takes the liberty to move
>>> some memory accesses that should occure between the irq disable/enable
>>> calls to a location before or after the irq disabled section. Try
>>> looking for a keyword like "memory barrier" on the mailing list archive
>> This was my first guess also but it fails with the edge of the 4.6 and
>> 4.7 branches
>> as well as using events for synchronization so it is most likely not the
>> barrier problem
>> again.
>> --joel
>>> wkr,
>>> Thomas.
>>> Johan Zandin schrieb:
>>>> Sergei Organov  writes:
>>>>> "Johan Zandin" <johan.zandin at space.se> writes:
>>>>>>       _Context_Switch( &executing->Registers, &heir->Registers );
>>>>>>       executing = _Thread_Executing;
>>>>>>       _ISR_Disable( level );         -----+
>>>>>>                                           |  Region where
>>>>>>    }                                      |  an occuring
>>>>>>                                           |  interrupt
>>>>>>     _Thread_Dispatch_disable_level = 0;   |  causes problems
>>>>>>     _ISR_Enable( level );            -----+
>>>>> But how interrupt can occur when it's disabled in this region?! If
>>>>> _ISR_Disable()/_ISR_Enable() don't work on your target, you have hard
>>>>> trouble anyway.
>>>> The HW interrupt occurs but is left pending until ISRs are enabled,
>>>> so the ISR does not execute until somewhere within the _ISR_Enable call
>>>> (in the first cycle when ISRs are enabled in the CPU again).
>>>> /Johan
>>>> Johan Zandin                      Software Engineer
>>>> Saab Space AB                     Phone: +46-31-735 41 47
>>>> SE-405 15 Gothenburg, Sweden      Fax:   +46-31-735 40 00
>>>> _______________________________________________
>>>> rtems-users mailing list
>>>> rtems-users at rtems.com
>>>> http://rtems.rtems.org/mailman/listinfo/rtems-users
>>> IMD Ingenieurbuero fuer Microcomputertechnik
>>> Thomas Doerfler           Herbststrasse 8
>>> D-82178 Puchheim          Germany
>>> email:    Thomas.Doerfler at imd-systems.de
>>> PGP public key available at:
>>>      http://www.imd-systems.de/pgpkey_en.html
>>> -----BEGIN PGP SIGNATURE-----
>>> Version: GnuPG v1.2.5 (MingW32)
>>> Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
>>> iD8DBQFGDBMswHyg4bDtfjQRAshFAJ9CCTaeF89pnc0/43dHX8OzUDnM2QCgjmuz
>>> LIoRrwohAlRbJJfF5mPNigk=
>>> =ihwI
>>> -----END PGP SIGNATURE-----
