Does RTEMS support PXA320?
Wed Aug 1 14:51:16 UTC 2007
Sang Won Yoo wrote:
> Thanks for the response.
> I have tried to look for the thread, but I haven't.
> Can anyone point me to the thread?
The links I got with Google: "xscale site:rtems.org"
didn't turn up anything useful either.  Just people asking.
This would require a new BSP but the existing ARM
port itself should be sufficient.  There is a Guide to
Writing BSPs and Device Drivers.  In general terms,
you start at "start.S" and work through until you
have hello, then ticker, then network demos running.  :-D
I would recommend finding a decent simulator for the
CPU and using it for some of the development.  Skyeye
probably supports the CPU model you are interested in.
If you want help, OAR and others are available to
write BSPs for you.  There is also a class August 21-24
here in Huntsville.  A significant part of the class is
on BSPs.
--joel
> Thanks in advance.
> SW Yoo
> On 7/31/07, *Amalaye Oyake* <amalaye.oyake at jpl.nasa.gov
> <mailto:amalaye.oyake at jpl.nasa.gov>> wrote:
>     This is one of the newer XScale processors (an ARM variant). RTEMS
>     people -
>     What is the status of the RTEMS XScale BSP? Can one simply use the
>     ARM BSP?
>     Can someone please list the general issues in getting an XScale BSP
>     developed. I think there was a thread about this a while back if I
>     remember.
>     Sincerely,
>     AO
>     ________________________________________
>     From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
>     <mailto:jpl.nasa.gov at rtems.org>
>     [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
>     <mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org>]
>     On Behalf
>     Of Sang Won Yoo
>     Sent: Tuesday, July 31, 2007 10:24 AM
>     To: rtems-users at rtems.org <mailto:rtems-users at rtems.org>
>     Subject: Does RTEMS support PXA320?
>     Hello RTEMS gurus,
>     I am new to this list to start with RTEMS for my new project.
>     The CPU on proejct has been determined to use PXA320. But not yet
>     determined
>     for RTOS.
>     After Ireviewed several RTOS, RTEMS is good enough for the
>     project. But I
>     am wondering if RTEMS
>     supports the CPU, PXA320 now. If so, please let me know where I
>     can start
>     with RTEMS.
>     Thanks for your attention.
> rtems-users mailing list
> rtems-users at rtems.com
