ARM Cross tools
    dave madden
    dhm at mersenne.com
    Fri Aug  3 06:31:33 UTC 2007
>>>>> "CJ" == Chris Johns <chrisj at rtems.org> writes:
    CJ> What is 'arm-generic-elf' ? Look in the path to the
    CJ> linker. You should have a rtems target name here, ie use an
    CJ> RTEMS linker rather than a generic ELF one.
"arm-generic-elf" was one of my attempts to build a toolchain.  I get
the same "hardware FP/software FP" and "failed to merge target
specific data" no matter what target I use.  I don't actually need an
rtems-specific toolchain, since rtems won't fit on my microcontroller.
But, several months ago, the rtems toolchain was the first one that
worked for me, so I'd stuck with it until I broke it.
    CJ> Do you have a path or environment error ?
Not that I know of -- I've been doing a complete rebuild of the
toolchain whenever I try a different version, compile options, or
target specifier.  (I rebuild binutils and gcc using the same options,
and clean out the destination directory before installing.)  I use
"verbose" mode when compiling, and all the stages and programs are
what I expect.
Thanks for the response...I'll try building with the rtems patches
again.
regards,
d.
