csb337 rtems build error
Roger advanceos at 163.com
Fri Dec 7 07:58:35 UTC 2007
Hello,
    I am new to rtems.I want to build rtems for my csb337 board.
But when I build rtems,the error as below.I don't know what is wrong!
I need a help.I am using MinGW Tools for Windows , rtems4.8-tools-16.exe and   rtems4.7.99.2.
$ ../rtems-4.7.99.2/configure --target=arm-rtems4.8 --enable-rtemsbsp=csb337 --
disable-posix --disable-itron --prefix=/opt/src/rtems/arm
checking for gmake... no
checking for make... make
checking for RTEMS Version... 4.7.99.2
checking build system type... i686-pc-mingw32
checking host system type... i686-pc-mingw32
checking target system type... arm-unknown-rtems4.8
checking for a BSD-compatible install... /bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking whether to enable maintainer-specific portions of Makefiles... no
configure: creating ./config.status
configure: configuring in ./tools/build
configure: running /bin/sh '../../../rtems-4.7.99.2/tools/build/configure' '--prefix=/opt/src/rtems/arm' '--host=i686-pc-mingw32' '--build=i686-pc-mingw32'  '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--target=arm-rtems4.8'  '--cache-file=/dev/null' '--srcdir=../../../rtems-4.7.99.2/tools/build'
checking for i686-pc-mingw32-gcc... no
checking for gcc... gcc
checking for C compiler default output file name... a.exe
checking whether the C compiler works... yes
checking whether we are cross compiling... no
checking for suffix of executables... .exe
checking for suffix of object files... o
checking whether we are using the GNU C compiler... yes
checking whether gcc accepts -g... yes
checking for gcc option to accept ISO C89... none needed
checking for style of include used by make... GNU
checking dependency style of gcc... gcc3
checking how to run the C preprocessor... gcc -E
checking for grep that handles long lines and -e... /bin/grep
checking for egrep... /bin/grep -E
checking for ANSI C header files... yes
checking for sys/types.h... yes
checking for sys/stat.h... yes
checking for stdlib.h... yes
checking for string.h... yes
checking for memory.h... yes
checking for strings.h... yes
checking for inttypes.h... yes
checking for stdint.h... yes
checking for unistd.h... yes
checking getopt.h usability... yes
checking getopt.h presence... yes
checking for getopt.h... yes
checking for strerror... yes
checking for strtol... yes
checking for bash... no
checking for ksh... no
checking for sh... /bin/sh
config.status: creating Makefile
config.status: creating install-if-change
config.status: creating config.h
config.status: config.h is unchanged
config.status: executing depfiles commands
configure: configuring in ./tools/cpu
configure: running /bin/sh '../../../rtems-4.7.99.2/tools/cpu/configure' '--prefix=/opt/src/rtems/arm' '--host=i686-pc-mingw32' '--build=i686-pc-mingw32'  '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--target=arm-rtems4.8'  '--cache-file=/dev/null' '--srcdir=../../../rtems-4.7.99.2/tools/cpu'
checking rtems target cpu... arm
=== configuring in generic (/opt/src/rtems/arm/tools/cpu/generic)
configure: running /bin/sh ../../../../rtems-4.7.99.2/tools/cpu/generic/configure '--prefix=/opt/src/rtems/arm'  '--host=i686-pc-mingw32' '--build=i686-pc-mingw32' '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--target=arm-rtems4.8' 'build_alias=i686-pc-mingw32' 'host_alias=i686-pc-mingw32' 'target_alias=arm-rtems4.8' --cache-file=/dev/null --srcdir=../../../../rtems-4.7.99.2/tools/cpu/generic
config.status: creating size_rtems
configure: configuring in ./testsuites/tools
configure: running /bin/sh '../../../rtems-4.7.99.2/testsuites/tools/configure' '--prefix=/opt/src/rtems/arm' '--host=i686-pc-mingw32' '--build=i686-pc-mingw32'  '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--target=arm-rtems4.8'  '--cache-file=/dev/null' '--srcdir=../../../rtems-4.7.99.2/testsuites/tools'
=== configuring in generic (/opt/src/rtems/arm/testsuites/tools/generic)
configure: running /bin/sh ../../../../rtems-4.7.99.2/testsuites/tools/generic/configure '--prefix=/opt/src/rtems/arm'  '--host=i686-pc-mingw32' '--build=i686-pc-mingw32' '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--target=arm-rtems4.8' 'build_alias=i686-pc-mingw32' 'host_alias=i686-pc-mingw32' 'target_alias=arm-rtems4.8' --cache-file=/dev/null --srcdir=../../../../rtems-4.7.99.2/testsuites/tools/generic
config.status: creating difftest
config.status: creating sorttimes
configure: configuring in arm-rtems4.8/c
configure: running /bin/sh '../../../rtems-4.7.99.2/c/configure' '--prefix=/opt/src/rtems/arm' '--host=arm-rtems4.8' '--build=i686-pc-mingw32' '--target=arm-rtems4.8'  '--enable-rtemsbsp=csb337' '--disable-posix' '--disable-itron' '--with-target-subdir=arm-rtems4.8' '--exec-prefix=/opt/src/rtems/arm/arm-rtems4.8' '--includedir=/opt/src/rtems/arm/arm-rtems4.8/include'  '--cache-file=/dev/null' '--srcdir=../../../rtems-4.7.99.2/c'
checking host system type... arm-unknown-rtems4.8
checking for arm-rtems4.8-strip... arm-rtems4.8-strip
checking for csb337.cfg... ../../../rtems-4.7.99.2/c/../make/custom/csb337.cfg
target architecture: arm.
available BSPs: csb337.
'make all' will build the following BSPs: csb337.
other BSPs can be built with 'make RTEMS_BSP="bsp1 bsp2 ..."'
config.status: creating make/Makefile
$ make all
Making all in make
make[1]: Entering directory `/opt/src/rtems/arm/make'
make[1]: Nothing to be done for `all'.
make[1]: Leaving directory `/opt/src/rtems/arm/make'
Making all in tools/build
make[1]: Entering directory `/opt/src/rtems/arm/tools/build'
make  all-am
make[2]: Entering directory `/opt/src/rtems/arm/tools/build'
make[2]: Leaving directory `/opt/src/rtems/arm/tools/build'
make[1]: Leaving directory `/opt/src/rtems/arm/tools/build'
Making all in tools/cpu
make[1]: Entering directory `/opt/src/rtems/arm/tools/cpu'
Making all in generic
make[2]: Entering directory `/opt/src/rtems/arm/tools/cpu/generic'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/opt/src/rtems/arm/tools/cpu/generic'
make[2]: Entering directory `/opt/src/rtems/arm/tools/cpu'
make[2]: Nothing to be done for `all-am'.
make[2]: Leaving directory `/opt/src/rtems/arm/tools/cpu'
make[1]: Leaving directory `/opt/src/rtems/arm/tools/cpu'
Making all in testsuites/tools
make[1]: Entering directory `/opt/src/rtems/arm/testsuites/tools'
make[2]: Entering directory `/opt/src/rtems/arm/testsuites/tools/generic'
make[2]: Leaving directory `/opt/src/rtems/arm/testsuites/tools/generic'
make[2]: Entering directory `/opt/src/rtems/arm/testsuites/tools'
make[2]: Leaving directory `/opt/src/rtems/arm/testsuites/tools'
make[1]: Leaving directory `/opt/src/rtems/arm/testsuites/tools'
Making all in arm-rtems4.8/c
make[1]: Entering directory `/opt/src/rtems/arm/arm-rtems4.8/c'
Making all in .
make[2]: Entering directory `/opt/src/rtems/arm/arm-rtems4.8/c'
make[2]: Leaving directory `/opt/src/rtems/arm/arm-rtems4.8/c'
Making all in csb337
make[2]: Entering directory `/opt/src/rtems/arm/arm-rtems4.8/c/csb337'
make[2]: *** No rule to make target `all'.  Stop.
make[2]: Leaving directory `/opt/src/rtems/arm/arm-rtems4.8/c/csb337'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/opt/src/rtems/arm/arm-rtems4.8/c'
make: *** [all-recursive] Error 1
        Roger
          2007-12-07
