[Fwd: Newlib 1.16.0 snapshot approaching]
Till Straumann
strauman at slac.stanford.edu
Tue Dec 11 21:03:49 UTC 2007
How about the newlib patch added in 1247 ?
This should be straightforward.
Then there is 1246 which also requires a newlib patch
but is more complicated.
IMO, at least 1247 should make it (but 1246 would also
be good. Currently, threads using stdin/stdout/stderr
leak memory when they are deleted (IIRC)).
T.
Joel Sherrill wrote:
> FYI.. time to clean out the closet. :-D
> --joel
> Subject:
> From:
> Jeff Johnston <jjohnstn at redhat.com>
> Date:
> Tue, 11 Dec 2007 14:25:09 -0500
> To:
> "'newlib at sources.redhat.com'" <newlib at sources.redhat.com>
> To:
> Sorry the late notice, but this is to inform people that I will making
> the annual newlib snapshot soon (1.16.0). To the usual suspects: if
> there is code you have been squirreling away, there's not a lot of
> time left. I hope to put the snapshot out next week some time,
> barring major last minute issues.
> -- Jeff J.
> rtems-users mailing list
> rtems-users at rtems.com
