Can't build CVS rtems-4-7-branch
Tue Feb 6 16:43:21 UTC 2007
Ralf Corsepius wrote:
> On Mon, 2007-02-05 at 15:49 -0800, Till Straumann wrote:
>> You might want to double-check Ralf's post from
>> over the week-end.
> Yes, it's related to it. I've started to commit changes related to
> declarations, to provoke the bug I am suspecting and plan to commit more
> similar changes in near future (probably today).
>> He probably changed the declaration of _CORE_message_queue_Seize
>> but you still pick up an old header that's in your build tree
>> ../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:
> May-be, may-be I missed something. I thought, I was carefully checking
> not to break something, but ... may-be I did - To be investigated.
It also looks like librtems++ does not compile.  I just committed changes
to get that to compile but it looks like the librtems++ test needs tweaking
also.
I will try to compile some more and see if I can fix that.
--joel
> Ralf
> rtems-users mailing list
> rtems-users at rtems.com
