Can't build CVS rtems-4-7-branch
Tue Feb 6 19:18:00 UTC 2007
I think I have fixed all the message queue compilation error issues in
4.7 and 4.8.  I
can compile for sparc/leon2 now anyway.
There is still a warning on the posix message queue code about losing a
const.
Probably the core message queue insert prototype should take a constant
pointer
but I haven't checked that yet.
--joel
Joel Sherrill wrote:
> Ralf Corsepius wrote:
>> On Mon, 2007-02-05 at 15:49 -0800, Till Straumann wrote:
>>> You might want to double-check Ralf's post from
>>> over the week-end.
>> Yes, it's related to it. I've started to commit changes related to
>> declarations, to provoke the bug I am suspecting and plan to commit more
>> similar changes in near future (probably today).
>>> He probably changed the declaration of _CORE_message_queue_Seize
>>> but you still pick up an old header that's in your build tree
>>> ../../cpukit/../../../mvme2100/lib/include/rtems/score/coremsg.h:
>> May-be, may-be I missed something. I thought, I was carefully checking
>> not to break something, but ... may-be I did - To be investigated.
> It also looks like librtems++ does not compile.  I just committed changes
> to get that to compile but it looks like the librtems++ test needs tweaking
> also.
> I will try to compile some more and see if I can fix that.
> --joel
>> Ralf
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
