ANNOUNCEMENT: rtems-4.8-testing repository
Ralf Corsepius
ralf.corsepius at rtems.org
Mon Feb 19 16:15:21 UTC 2007
Hi,
I've set up a new hierarchy of toolchain rpm-repositories, which is
supposed to take experimental toolchain rpms.
c.f. ftp://ftp.rtems.org/pub/rtems/linux/testing/<rtems-version>
ATM, available are experimental versions of
*-rtems-4.8-gcc-4.1.2
and
*-rtems-4.8-gdb-6.6
NOTE:
* These repositories are add-on repositories to the "nominal"
repositories, i.e. they are supposed to be used in conjunction with the
repositories living under
ftp://ftp.rtems.org/pub/rtems/linux/<rtems-version>
* yum users having at least rtems-4.8-yum-conf-0.5-1 (available since
this morning) installed, can enable them through editing
/etc/yum.repos.d/rtems-<rtems-version>.repo
or by using
yum --enablerepo=rtems-4.8-testing ...
If you don't understand all this, ... sorry, then this probably isn't
for you ;)
Ralf
