Unexpected trap (0x04) fp disabled
Patricia Lopez-Cueva
Patricia.Lopez-Cueva at scisys.co.uk
Mon Feb 19 17:12:03 UTC 2007
Hi all.
I have tried to run a simple test in sparc-rtems-gdb and I get the
following error:
Unexpected trap (0x04) at address 0x40004ee8
fp disabled
The backtrace shows:
Program exited with code 0362.
(gdb) bt
#0 syscall ()
at
../../../../../../../../rtems-4.6.5/c/src/lib/libcpu/sparc/syscall/sysca
ll.S:54
#1 0x40003ba8 in DEBUG_puts (string=0xf2000fe7 "")
at
../../../../../../../../../rtems-4.6.5/c/src/lib/libbsp/sparc/leon2/cons
ole/debugputs.c:108
#2 0x40003fa8 in bsp_spurious_handler (trap=2779096485, isf=0xa5a5a5a5)
at
../../../../../../../../../rtems-4.6.5/c/src/lib/libbsp/sparc/leon2/star
tup/spurious.c:122
#3 0xa5a5a5ad in ?? ()
#4 0xa5a5a5ad in ?? ()
Previous frame identical to this frame (corrupt stack?)
I thought it was because of I didn't put the floating point attribute
for the rtems task but it still fails with the same error.
#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
I don't know if there is any error in the thread creation with
pthread_create or anything else.
Thanks for your help
Patricia
URL: <http://lists.rtems.org/pipermail/users/attachments/20070219/c296bbf6/attachment.html>
