RPM testing repo feedback
    Joel Sherrill
    joel.sherrill at oarcorp.com
    Wed Feb 21 23:49:38 UTC 2007
Hi,
It looks like the tools in the testing repository
are reasonably ok.  I have used the powerpc psim
and mips jmr3904 simulators in gdb to run tests.
I have built all BSPs and I think the set that
doesn't build is the same as with the other tools.
I have NOT:
  + run all tests on sparc/sis
  + investigated the BSP build failures.  I will
    follow up and report on these.  I need to compare
    4.7 and 4.8 build failures for patterns.
--joel
