System V semaphores and ipc?
Joel Sherrill
joel.sherrill at oarcorp.com
Mon Feb 5 14:32:39 UTC 2007
Amalaye Oyake wrote:
> Does RTEMS support UNIX System V semaphores and ipc?
> Specifically I am looking for:
> sys/ipc.h - interprocess communication access structure
> sys/msg.h - message queue structures
> Now I know that RTEMS is not UNIX, but do these headers exist in some
> form? I see some stuff like sys/types.h - data types … if they do not
> I shall use the POSIX mapping.
RTEMS supports POSIX message queues and semaphores.
It does NOT support any of the shm* or mmap related calls. In addition, you
can't fork a process. :)
In general, the first place to look for concurrency calls is
cpukit/posix/src. File access
and libc code is generally divided between libcsupport and newlib.
--joel
--joel
> Sincerely
> * Amalaye Oyake *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work 818.653.4748 cell *||
> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
> @@@ personal opinions expressed represent only the views of the author @@@
> rtems-users mailing list
> rtems-users at rtems.com
