configure: error: Missing RTEMS_BSP
Chris Caudle chris at chriscaudle.org
Wed Feb 7 19:39:16 UTC 2007
On Wed, February 7, 2007 2:32 pm, Jonathan Kalbfeld wrote:
> If you want to build the POSIX tests you don't need to specify a BSP.
> It should build them as UNIX executables.
Are you perhaps confusing the little-used Posix BSP with the tests which
exercise the POSIX API mapping of RTEMS?
Chris Caudle
