configure: error: Missing RTEMS_BSP
Amalaye Oyake amalaye.oyake at jpl.nasa.gov
Wed Feb 7 19:47:25 UTC 2007
Thanks guys .. case cleared up. These tests were already built as part of my
BSP.
~/RTEMS/tools/i386-rtems/pc686/lib/rtems-4.7/tests$ ls
base_sp.doc     paranoia.doc  psx08.scn        psxmount.scn    sp01.doc
sp07.doc  sp14.doc  sp21.doc  sp27.doc    spsize.scn    tm06.exe  tm15.exe
tm24.exe
base_sp.exe     paranoia.exe  psx09.exe        psxmsgq01.exe   sp01.exe
sp07.exe  sp14.exe  sp21.exe  sp27.exe    stackchk.exe  tm07.doc  tm16.doc
tm25.doc
base_sp.scn     pppd.exe      psx09.scn        psxmsgq01.scn   sp01.scn
sp07.scn  sp14.scn  sp21.scn  sp27.scn    stackchk.scn  tm07.exe  tm16.exe
tm25.exe
-----Original Message-----
From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
[mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
Of Chris Caudle
Sent: Wednesday, February 07, 2007 11:39 AM
To: rtems-users at rtems.org
Subject: Re: configure: error: Missing RTEMS_BSP
On Wed, February 7, 2007 2:32 pm, Jonathan Kalbfeld wrote:
> If you want to build the POSIX tests you don't need to specify a BSP.
> It should build them as UNIX executables.
Are you perhaps confusing the little-used Posix BSP with the tests which
exercise the POSIX API mapping of RTEMS?
Chris Caudle
rtems-users mailing list
rtems-users at rtems.com
http://rtems.rtems.org/mailman/listinfo/rtems-users
