Web server
Lars Törnkvist
lars.tornkvist at solidsoftware.net
Thu Feb 15 09:36:51 UTC 2007
Hi,
Thank you Steven. shttpd seems the way to go then. Especially with the SSI and security patches.
/ Lars Törnkvist
> -----Original Message-----
> From:
> rtems-users-bounces+lars.tornkvist=solidsoftware.net at rtems.org
> [mailto:rtems-users-bounces+lars.tornkvist=solidsoftware.net at r
> tems.org] On Behalf Of Steven Johnson
> Sent: den 13 februari 2007 22:30
> Cc: rtems-users at rtems.org
> Subject: Re: Web server
> Hi,
> I am not a fan of the GoAhead Webserver. We have it in our
> product, but we are going to replace it with the shttpd one.
> I wrote the port for shttpd and rtems, it is in the official
> shttpd tree. see http://shttpd.sourceforge.net/
> The BIG missing feature's by comparison to GoAhead are:
> 1. Server Side Includes (which GoAhead calls ASP, which isn't ASP).
> 2. A Security API to allow security to be set in software,
> rather than using a security file (shttpd supports a security file).
> I have just written support for Server Side Includes, it has
> only been tested by me, and it isn't integrated into the
> mainline yet, but the patches are in the mailing list if
> anyone wants them.
> GoAhead is larger (in code size) than shttpd. Without giving
> a much larger set of capabilities as far as what I imagine
> typical use in an RTEMS application would be. It is also
> unmaintained and contains a number of bugs (see my post that
> Joel links to).
> The API's are totally different, so it is not easy to just
> plug in shttpd into a program that uses GoAhead. I also
> don't think that a simple API translation layer could be
> written because the API's are quite different where it
> matters. I also however do not think it would be a huge deal
> to cut a program using GoAhead over to shttpd.
> There is also the issue that the GoAhead in RTEMS is old,
> V2.1.4, the latest official GoAhead is V2.1.8 and there are a
> number of known bugs to that version, my patches in my
> previous post seek to update the version and to address as
> many known faults as possible. Unfortunately the licence is
> confusing, there are several subtly different versions, but
> it would seem to me that applying my patches to the mainline
> and making them publicly available as a patched version of
> GoAhead would violate at least one of the variant licences.
> There is also my pet hate, the server must report itself as a
> GoAhead server and official version (2.1.4 for RTEMS). If
> you apply patches to it, it is against the licence to change
> this version number. You also need to put the GoAhead logo
> on your home page.
> shttpd by contrast is a fully permissive licence (Beerware),
> free for Commercial or Open Source use without restriction,
> and there is no advertising clause, and you can make the
> server respond with any server name/version that you like, so
> that it can match your application.
> I am still working on shttpd, and we are going to integrate
> it into our product and totally replace GoAhead. Part of
> that will require I add missing feature 2 above. I expect
> this should be complete some time next week.
> I think as a way forward, given the lack of API compatibility
> would be to provide a copy of the shttpd tree (current as at
> any release) and let people decide what they want to use,
> with a note saying GoAhead is obsoleted, for the obvious
> reasons (unsupported and restrictive licence) and that people
> are encouraged to use shttpd (or another server of their
> choice), and then have a road map to drop GoAhead totally in
> a couple of
> releases. Maybe leave GoAhead as the only web server for the next
> version (4.7), have both present in the version after the
> next one (RTEMS 4.8?) and drop Go Ahead for (4.9). If anyone
> still wants to use GoAhead in 4.9 or after, there would be
> nothing stopping them taking the code base from RTEMS and
> sticking it in their own tree, it just wouldn't be officially
> maintained in the RTEMS tree any more.
> Steven Johnson
> Joel Sherrill wrote:
> > John Mills wrote:
> >> Lars, all -
> >> I have just finished integrating the GoAhead server with an eCos
> >> application and I went back over the RTEMS mailing lists
> when I read Lars'
> >> note. I didn't find any recent correspondence -- did
> anyone summarize
> >> 'Pros' and 'Cons' (as well as alternatives)?
> > The main issue was that the GoAhead server appears to be no longer
> > maintained by its authors. We have tolerated its licensing
> > requirement for advertising since we didn't have another
> alternative.
> > Start here:
> > http://www.rtems.org/ml/rtems-users/2006/october/msg00088.html
> > Steven Johnson is across the world from us so I wouldn't expect a
> > comment from him for a few more hours. I hoep he can
> update us on the
> > status. It seemed to be in good shape the last I knew.
> >>> >From my viewpoint, I fought through GoAhead's the 'POST'
> upload in
> >>> >a
> >> couple of flavors and got it working both with GoAhead's embedded
> >> 'goforms' and conventional CGI, in Linux and eCos. I also found it
> >> useful to export the library and to link it to a thread in our app
> >> where I generate the web content.
> >> Finally, in response to the questions about a separate
> build of the
> >> compiled web content (using conventional HTML), notice that the
> >> precompiler 'webcomp' is a native tool of your development
> host. Even
> >> though you it '#include's many of the source package's headers, it
> >> can be build in the source tree and comes out as a self-contained
> >> command-line app that generates a *.c file which becomes
> part of your library source.
> >> Build 'webcomp' once and move it aside to use independently. See
> >> GoAhead's Makefile for usage of 'webcomp' and on linking
> the library.
> >> (A suitable target already exists.)
> > The only technical gripes against GoAhead were that it seemed to be
> > unmaintained and that it does not compile warning free with
> late model
> > gcc's. The advertising clause in the license is just
> another factor.
> >> That said, I would be interested in a discussion (or references to
> >> earlier
> >> discussions) of concerns and alternative web-servers for RTEMS (and
> >> similar) environments. One point I missed was the fate of the JAWS
> >> server that I thought had once been a good choice for RTEMS use.
> >> Thanks.
> >> - John Mills
> >> john.m.mills at alum.mit.edu
> >> On Tue, 13 Feb 2007, Lars Törnkvist wrote:
> >>> Some time ago there was a short discussion about which
> web server to
> >>> use with RTEMS instead of the GoAhead one. shttpd was one
> example mentioned.
> >>> We are soon going to start working on web server
> functionality and
> >>> are interested in any information we can get about this.
> >>> Regards
> >>> Lars Törnkvist
> >>> Solid Software AB
> >> _______________________________________________
> >> rtems-users mailing list
> >> rtems-users at rtems.com
> >> http://rtems.rtems.org/mailman/listinfo/rtems-users
