How do I load hello.exe to my lite5200?
Duncan Winn
duncan at winnd.sparks.nv.us
Thu Feb 22 23:21:02 UTC 2007
Nickolay Kolchin wrote:
> On 2/22/07, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
>> The make-exe rule leaves the file in ELF format so is that what u-boot
>> can load? Do you do anything special to the linked image before
>> downloading it with u-boot?
> I'm using this commands in linux shell:
> $ powerpc-rtems-objcopy -O binary --strip-unneeded hello.exe hello.bin
> $ mkimage -A ppc -O rtems -T kernel -a 0x100 -e 0x10000 -n "RTEMS" \
> -C none -d hello.bin hello.img
> and then load "hello.img" with U-Boot: tftpboot; bootm
> mkimage --- is an utility provided with U-Boot (look inside tools
> directory).
>> Is there anyone out there using the Motorola lite5200 or is everyone
>> using 3rd party or custom boards?
> FreeScale lite5200b. Afaik, original 5200 is obsolete and not produced
> any more.
>> --joel
>> > On 2/22/07, Duncan Winn <duncan at winnd.sparks.nv.us> wrote:
>> >> I would like to run RTEMS on a Motorola lite5200 board. This
>> board uses
>> >> the MPC5200 processor. I was able to build RTEMS using the
>> pm520-ze30
>> >> bsp. At first, I thought I should be using the gen5200 bsp, but I
>> >> couldn't get it to build.
>> >> My question is, is the pm520-ze30 the right bsp? What part of the
>> bsp
>> >> would I need to modify in order to get hello.exe running on the
>> >> lite5200? How do I go about downloading hello.exe to the board.
>> When
>> >> the board boots up, it gives me a dBUG> prompt from the Motorola
>> >> standard monitor program. I was able to build and download a
>> version of
>> >> u-boot to the board if this will make it easier to load RTEMS. I was
>> >> also able to build and download ELDK Linux (2.4.25) to the board, but
>> >> this didn't get me any closer to RTEMS. Any help would be greatly
>> >> appreciated.
> Nickolay
Thank you for your help. I successfully loaded my hello.bin as
hello.img and then I tried to let it autoboot the way it did while
running the Linux image (using tftp, bootm). It told me that it had
loaded hello.img, but I got garbage characters on my terminal window and
changing the baud rate did not seem to help. The hello.exe file I got from
<my home
directory>/tools/build-rtems/powerpc-rtems4.7/c/pm520_ze30/testsuites/samples/hello
Thank you,
Duncan Winn
