Problems about porting RTEMS on a BSP close to mbx8xx
Thomas Doerfler Thomas.Doerfler at embedded-brains.de
Fri Feb 23 16:33:21 UTC 2007
Julien,
Am Freitag, 23. Februar 2007 16:37 schrieb Julien Delange:
> ./configure --target=powerpc-rtems --prefix=/path/to/install/rtems only.
> There is no NVRAM and no EPPCBug, we have more 64Mo of RAM. The
> processor is a mpc860.
The I would try the following "configure" command line:
configure\
 --enable-rtemsbsp="mbx860_002b"\
 --target=powerpc-rtems4.7 --prefix=/opt/rtems-4.7/4.7\
  NVRAM_CONFIGURE=0\
 PRINTK_IO_MODE=0 PRINTK_MINOR=SMC1_MINOR \
 CONSOLE_MINOR=SMC1_MINOR UARTS_IO_MODE=0 UARTS_USE_TERMIOS=1
This should force the "itteligent" stuff off in the console driver.
wkr,
Thomas.
> > - Can you tell me, whether you are also using the EPPCBug as boot
> > monitor?
> No, we don't use this monitor, we use ppcboot instead.
> Thanks for everything,
> Regards,
> rtems-users mailing list
> rtems-users at rtems.com
Embedded Brains GmbH
Thomas Doerfler           Obere Lagerstr. 30
D-82178 Puchheim          Germany
email: Thomas.Doerfler at embedded-brains.de
Phone: +49-89-18908079-2
Fax:   +49-89-18908079-9
