timer_settime doesn't fill siginfo_t
Patricia Lopez-Cueva Patricia.Lopez-Cueva at scisys.co.uk
Wed Feb 28 12:14:43 UTC 2007
Many thanks for your suggestion.
The problem is _POSIX_signals_Unblock_thread saves the value but then it
does not do anything with it. That function calls to
_Thread_queue_Extract_with_proxy with the thread but with no more
information.
Is there any way to pass the information?
-----Original Message-----
From: Joel Sherrill [mailto:joel.sherrill at oarcorp.com]
Sent: 28 February 2007 01:29
To: Marek Prochazka
Cc: Patricia Lopez-Cueva; rtems-users at rtems.org
Subject: Re: timer_settime doesn't fill siginfo_t
Marek Prochazka wrote:
> It seems to me that RTEMS implementation of POSIX timers just does not
> pass the sigev_value data structure at all. It saves the value in the
> timer_create():
> ptimer1.c:
>         if ( evp != NULL ) {
>            timer_struct[timer_pos].inf.sigev_notify =
evp->sigev_notify;
>            timer_struct[timer_pos].inf.sigev_signo  =
evp->sigev_signo;
>            timer_struct[timer_pos].inf.sigev_value  =
evp->sigev_value;
> But in FIRE_TIMER_S(), which is the function called when a timer
> expires, pthread_kill() is used and this obviously only passes signal
> number and not other values which should be passed (e.g. si_code ==
> SI_TIMER, and also the sigev_value).
> A question for RTEMS experts is whether this could be fixed somehow.
I completely reimplemented this between 4.6 and 4.7 but the call to
pthread_kill
is still at the middle.
With me teaching the class this week, I don't have much time to even
make a suggestin
but I think I have one.  Please try to convert the call to pthread_kill
to a call to
boolean _POSIX_signals_Unblock_thread(
  Thread_Control  *the_thread,
  int              signo,
  siginfo_t       *info
Does that look like it will help?
Can you try to remedy it in your source and submit a patch along with a
test case?
--joel
--joel
> Marek
>> From:
>> rtems-users-bounces+marek.prochazka=scisys.co.uk at rtems.org
>> [mailto:rtems-users-bounces+marek.prochazka=scisys.co.uk at rtems
>> .org] On Behalf Of Patricia Lopez-Cueva
>> Sent: 27 February 2007 16:33
>> To: rtems-users at rtems.org
>> Subject: timer_settime doesn't fill siginfo_t
>> Hi all.
>> I'm programming an application that uses Posix timers in
>> rtems.  I have to pass to the signal handler information so I
>> have to use SA_SIGINFO and put the information in the
>> sigevent structure.
>> The problem is that when the handler is called and I access
>> to the siginfo_t parameter and in the si_value.sival_ptr the
>> information I store is not there.
>> Following it is included the code:
>>         struct sigevent t_Evp;
>>         struct sigaction t_SigAction;
>>         /* Initialise signal handler */
>>         sigemptyset(&t_SigAction.sa_mask);
>>         t_SigAction.sa_flags = SA_SIGINFO;
>>         t_SigAction.sa_sigaction = &SignalHandler;
>>         if (0 != sigaction(SIGUSR1, &t_SigAction, NULL))
>>                 ERROR("Failed to install signal handler using
>> sigaction\n");
>>                 return G_STATUS_FAILURE;
>>         /* Create timer */
>>         DEBUG("Creating POSIX timer\n");
>>         t_Evp.sigev_notify = SIGEV_SIGNAL;
>>         t_Evp.sigev_signo = SIGUSR1;
>>         t_Evp.sigev_value.sival_ptr = &pt_Timer;
>>         if (0 != (i_Status = timer_create(CLOCK_REALTIME,
>> &t_Evp, &pt_Timer)))
>>                 ERROR("Failed to create timer using timer_create\n");
>>                 switch (errno)
>>                         case EAGAIN:
>>                                 ERROR("EAGAIN: Lacked
>> necessary resources or too many timers\n");
>>                                 break;
>>                         case EINVAL:
>>                                 ERROR("EINVAL: Invalid
>> attributes or clock id\n");
>>                                 break;
>>                         default:
>>                                 ERROR1("Unknown error = %d\n",
errno);
>>                 errno = 0;
>> static void SignalHandler(
>>         int             i_Signo,
>>         siginfo_t * pt_Info,
>>         void *          pv_Context);
>> Is there any error in the code? Someone knows why it happens?
>> Many thanks
>> Patricia
> rtems-users mailing list
> rtems-users at rtems.com
