MPC5200 RTEMS Tick
Simon Yuen syuen at topcon.com
Thu Jan 25 17:56:03 UTC 2007
I am a newbie to RTEMS and the MPC5200.   My project requires a timely
periodic task to run every 1ms but I am not sure how to approach this.
Here are a few questions I hope someone can shed some light on.
1)       If I set CONFIGURE_MICROSECONDS_PER_TICK to give me a 1ms tick,
how much overhead would this cause to program execution running two
tasks?  I like to use the rate monotonic manager to run a task every
1ms.
2)       On the other hand, if RTEMS is servicing ticks at 10ms and I
use an available timer to give me interrupts every 1ms to run an ISR.
How does this periodic interrupt affect task execution since RTEMS needs
to manage this interrupt?
3)       Which is the better approach?
Thank you
Simon
URL: <http://lists.rtems.org/pipermail/users/attachments/20070125/5e10f029/attachment.html>
