Slow event responses (~400ms)
rg
rg at irfu.se
Fri Jan 26 10:42:23 UTC 2007
Joel Sherrill wrote:
> rg wrote:
>> Remailed with an intelligent subject..
>> Hi
>> I have just started programming rtems.
>> And I see a slow response to events in the order
>> of 400ms or on my system 80 ticks
>> (50MHz Leon2 CPU) RTEMS 4.6
>> I need a event response time closer to 10 ms, or 2 ticks.
>> I am measuring the response time by setting an IO output
>> just after sending the event and clearing it after receiving it
>> in the receiving task..and then I measure on a oscillioscope....
>> (difficult to spell that one...)
>> Ive tested by sending the event from a ISR and also a task...
>> all tasks have the same priority and are preemptive, tested to have
>> the receiving task no preemptive..this gives slightly better results
>> otherwise the results are the same.
> This is the problem. You have a lot of tasks at the same priority and
> preemption
> really isn't going to be the factor. Tasks are in a FIFO per priority
> and every task
> ahead of the one receiving the event will have to run and give up the
> CPU (block or
> yield) before the task receiving the event will run.
> If you made the task receiving the event higher priority than the
> other tasks and
> those lower priority tasks were preemptive, the number would be MUCH
> lower.
> Most of the time, the higher priority task would execute immediately
> after the ISR
> exits.
> This is an application design/tuning issue which could occur on any
> priority based
> operating system.
> --joel
>> mrr
>> rtems-users mailing list
>> rtems-users at rtems.com
>> http://rtems.rtems.org/mailman/listinfo/rtems-users
Ok I tested your suggestion and now its down to 22 us about ~18000
times faster...Im happy :)
mrr
