Which patches should I use for binutils, gcc and newlib? *limits.h*
Thu Jan 25 18:09:48 UTC 2007
Amalaye Oyake wrote:
> I should have been more specific. I asked what patch I should use b/c
> I was bombing out compiling gcc 4.1.1 … it complains about limits.h
This looks like a configure problem. What command did you configure
with? Did you include --with-newlib?
> make[4]: Entering directory `/home/coder/RTEMS/build-gcc/gcc'
> make[4]: `crtend.o' is up to date.
> make[4]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
> /home/coder/RTEMS/build-gcc/./gcc/xgcc
> -B/home/coder/RTEMS/build-gcc/./gcc/
> -B/home/coder/RTEMS/tools/i386-rtems/bin/
> -B/home/coder/RTEMS/tools/i386-rtems/lib/ -isystem
> /home/coder/RTEMS/tools/i386-rtems/include -isystem
> /home/coder/RTEMS/tools/i386-rtems/sys-include -O2
> -I../../gcc-4.1.1/gcc/../newlib/libc/sys/rtems/include -O2 -g -O2
> -DIN_GCC -DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes
> -Wmissing-prototypes -Wold-style-definition -isystem ./include -g
> -DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED
> -Dinhibit_libc -I. -I. -I../../gcc-4.1.1/gcc -I../../gcc-4.1.1/gcc/.
> -I../../gcc-4.1.1/gcc/../include
> -I../../gcc-4.1.1/gcc/../libcpp/include -DL_fixunsdfsi -c
> ../../gcc-4.1.1/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
> In file included from
> /home/coder/RTEMS/build-gcc/./gcc/include/syslimits.h:7,
> from /home/coder/RTEMS/build-gcc/./gcc/include/limits.h:11,
> from ../../gcc-4.1.1/gcc/libgcc2.c:1469:
> /home/coder/RTEMS/build-gcc/./gcc/include/limits.h:122:61: error: no
> include path in which to search for limits.h
> make[3]: *** [libgcc/./_fixunsdfsi.o] Error 1
> make[3]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
> make[2]: *** [stmp-multilib] Error 2
> make[2]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
> make[1]: *** [all-gcc] Error 2
> make[1]: Leaving directory `/home/coder/RTEMS/build-gcc'
> make: *** [all] Error 2
> Ho do I fix this?
> -AO
> *From:* rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
> [mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] *On
> Behalf Of *Amalaye Oyake
> *Sent:* Wednesday, January 24, 2007 10:23 PM
> *To:* rtems-users at rtems.org
> *Subject:* Which patches should I use for binutils, gcc and newlib?
> Hello,
> I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit Xeon
> host box running Ubuntu (64bit) … my target system will be a i386 box.
> What are the correct patches for Binutils, Gcc and Newlib? I see a lot
> of /.diff/ files in http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I
> don’t know if I am to use all of them or just the latest one …
> Regards,
> * Amalaye Oyake *
> * Flight Software Applications & Data Product Mgmt */\
> * 818.393.7168 work 818.653.4748 cell *||
> * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
> @@@ personal opinions expressed represent only the views of the author @@@
> rtems-users mailing list
> rtems-users at rtems.com
