Which patches should I use for binutils, gcc and newlib? *limits.h*
Amalaye Oyake
amalaye.oyake at jpl.nasa.gov
Thu Jan 25 17:57:19 UTC 2007
I should have been more specific. I asked what patch I should use b/c I was
bombing out compiling gcc 4.1.1 . it complains about limits.h
make[4]: Entering directory `/home/coder/RTEMS/build-gcc/gcc'
make[4]: `crtend.o' is up to date.
make[4]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
/home/coder/RTEMS/build-gcc/./gcc/xgcc -B/home/coder/RTEMS/build-gcc/./gcc/
-B/home/coder/RTEMS/tools/i386-rtems/bin/
-B/home/coder/RTEMS/tools/i386-rtems/lib/ -isystem
/home/coder/RTEMS/tools/i386-rtems/include -isystem
/home/coder/RTEMS/tools/i386-rtems/sys-include -O2
-I../../gcc-4.1.1/gcc/../newlib/libc/sys/rtems/include -O2 -g -O2 -DIN_GCC
-DCROSS_COMPILE -W -Wall -Wwrite-strings -Wstrict-prototypes
-Wmissing-prototypes -Wold-style-definition -isystem ./include -g
-DHAVE_GTHR_DEFAULT -DIN_LIBGCC2 -D__GCC_FLOAT_NOT_NEEDED -Dinhibit_libc -I.
-I. -I../../gcc-4.1.1/gcc -I../../gcc-4.1.1/gcc/.
-I../../gcc-4.1.1/gcc/../include -I../../gcc-4.1.1/gcc/../libcpp/include
-DL_fixunsdfsi -c ../../gcc-4.1.1/gcc/libgcc2.c -o libgcc/./_fixunsdfsi.o
In file included from
/home/coder/RTEMS/build-gcc/./gcc/include/syslimits.h:7,
from /home/coder/RTEMS/build-gcc/./gcc/include/limits.h:11,
from ../../gcc-4.1.1/gcc/libgcc2.c:1469:
/home/coder/RTEMS/build-gcc/./gcc/include/limits.h:122:61: error: no include
path in which to search for limits.h
make[3]: *** [libgcc/./_fixunsdfsi.o] Error 1
make[3]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
make[2]: *** [stmp-multilib] Error 2
make[2]: Leaving directory `/home/coder/RTEMS/build-gcc/gcc'
make[1]: *** [all-gcc] Error 2
make[1]: Leaving directory `/home/coder/RTEMS/build-gcc'
make: *** [all] Error 2
Ho do I fix this?
-AO
_____
From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
[mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
Of Amalaye Oyake
Sent: Wednesday, January 24, 2007 10:23 PM
To: rtems-users at rtems.org
Subject: Which patches should I use for binutils, gcc and newlib?
Hello,
I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit Xeon host
box running Ubuntu (64bit) . my target system will be a i386 box. What are
the correct patches for Binutils, Gcc and Newlib? I see a lot of .diff files
in http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I don't know if I am to
use all of them or just the latest one .
Regards,
* Amalaye Oyake *
* Flight Software Applications & Data Product Mgmt */\
* 818.393.7168 work 818.653.4748 cell *||
* Jet Propulsion Laboratory, Pasadena CA 91109 */||\
@@@ personal opinions expressed represent only the views of the author @@@
URL: <http://lists.rtems.org/pipermail/users/attachments/20070125/d0a70342/attachment.html>
