Convert Linker Output to Binary File
frank.ueberschar at dsa-volgmann.de frank.ueberschar at dsa-volgmann.de
Tue Jan 30 10:37:17 UTC 2007
Thank you for help,
we recently got this working (MinGW, MSYS, rtems4.7 toolset):
- rebuilt RTEMS, newlib and the application with the -fno-merge-constants
  Flag. After this the unmotivated 0x0 Adresses (.rodata.str1) in the map
  file disappeared.
- there has been one extra memory section in our linker script
  used only to check sizeof some structures.
  Even if this was a NOLOAD Section we got Adresses 0x0 into
  the elf-output. After moving the Adress space into the application
  space it happened to be no problem.
Having done all this objcopy creates a usable binary file
out of the linker elf32-m68k output.
Best regards,
Frank
To: joel.sherrill at oarcorp.com
Cc: ianc at goanna.iinet.net.au
    rtems-users at rtems.org
