Which patches should I use for binutils, gcc and newlib?
    Amalaye Oyake
    amalaye.oyake at jpl.nasa.gov
    Tue Jan 30 20:34:45 UTC 2007
With some wheel spinning I was able to build everything and I am chugging
happily along. I built the stuff by hand (which is usually my preferred
way), because my host system is an 64bit x86 Ubuntu box ...
As a Debian/Ubuntu person I used to be a bit biased against RPMs, but I have
since discovered their usefulness (especially SRPMS).
- AO
-----Original Message-----
From: rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org
[mailto:rtems-users-bounces+amalaye.oyake=jpl.nasa.gov at rtems.org] On Behalf
Of Till Straumann
Sent: Tuesday, January 30, 2007 12:23 PM
To: Joel Sherrill
Cc: rtems-users at rtems.org
Subject: Re: Which patches should I use for binutils, gcc and newlib?
> Amalaye Oyake wrote:
> > Hello,
> > I am trying to build Binutils Gcc (4.1.1) and Newlib on a 64bit Xeon
> > host box running Ubuntu (64bit) ? my target system will be a i386 box.
> > What are the correct patches for Binutils, Gcc and Newlib? I see a lot
> > of /.diff/ files in http://www.rtems.com/ftp/pub/rtems/SOURCES/ that I
> > don?t know if I am to use all of them or just the latest one ?
> In general, it is always a single patch and choose the one with the
> latest date. That
> may NOT be the case for specific CPUs which may not work with the latest
> version
> of something or require a special patch.
Just for the record...
> For specific and absolutely correct information, check out
I assume you mean to look in CVS. If I browse in cvsweb
to [there is no 'rtems-XXX', just 'rtems']
rtems/contrib/crossrpms/rtems4.7/<my_cpu>
then I end up an the 'Attic' -- so much for 'absolutely correct information'
It would help if the precise information about what toolkit and patch
versions to use were available [or at least 'absolutely correct information'
about where to find it]. Not everybody uses the pre-packaged RPMs.
-- Till
> rtems-XXX/contrib/crossrpms/rtemsX.Y/CPU/*.add
> --joel
> > Regards,
> > * Amalaye Oyake *
> > * Flight Software Applications & Data Product Mgmt */\
> > * 818.393.7168 work 818.653.4748 cell *||
> > * Jet Propulsion Laboratory, Pasadena CA 91109 */||\
> > @@@ personal opinions expressed represent only the views of the author
> > rtems-users mailing list
> > rtems-users at rtems.com
> > http://rtems.rtems.org/mailman/listinfo/rtems-users
> *References*
